Jim A. Banville
- Jun 20, 1999
Do you think that the "green CD marking pens" can make a difference in the sound of CDs?
I have actuall tried that too! There is a reasonable theory behind it. It is supposed to absorb stray "light" that bounces around inside the plastic disc. Makes sense to me, just as placing sound absorbing materials in a room would absorb sound waves bouncing around. Did I hear a difference with the paint? Nope. During your test, were you aware of which CD you were listening to (painted/non-painted), or was it a "blind" test? If it were blind and you were 100% correct (and the tester told you the test was random and he may or may not switch CD's) then I would say that you proved you could hear a difference. Again, true or not, there is a reasonable theory behind it. There is no reasonable theory why two cables that measure the same would "sound" different.
