Why receiver only has 1 RCA for sub out but Sub has 2 RCA inputs?
Discussion in 'Speakers & Subwoofers' started by Tim_, Apr 19, 2005.
  1. Tim_
    Tim_ Stunt Coordinator
    Mar 25, 2005
    95
    1) Does it matther if I connect both to both input on the subwoofer with a spliter?
    2) Or I can just plug into either 'L' or 'R'?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Sub has stereo inputs in case you want to run it off main channels in line with other speakers. Check your manual, one may be the "preferred" one for a sinle input. I typically recommend using a splitter, but after calibration, it works out to be the same thing.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I always use splitters for them. Some equipment will have stereo sub outs, but most are only one mono /LFE sub out.
    I probably don't have to use the splitters anymore, but, since I have always done it this way with success, I suppose I will continue to do so.
