Why no VMPS?
Discussion in 'Archived Threads 2001-2004' started by John A. Casler, Dec 15, 2001.
  1. John A. Casler
    John A. Casler Second Unit
    Apr 29, 1999
    475
    In all the value and MONSTER sub discourse, I seldom see any reference to the price/value/performance of the VMPS Larger Sub.
    Is it because it is not "powered" or because some don't think it lives up to claims? or maybe because it is the size of a small refrigerator?
    How many subs will put out 115dB/1m SPL at 20Hz with 2.5% THD for $700 shipped? (remember the distortion number)
    See below;
    The New Larger Subwoofer
    Frequency Response: +0, -3dB, 17Hz to 250 Hz
    THD: 0.5% 20Hz to 250 Hz with 1W drive
    Sensitivity: 92 dB/1W/1m
    Maximum undistorted output: at least 115dB/1m SPL at 20Hz for 2.5% THD
    Drive Complement: 12" polycone active (or 12" WCF active), 15" polycone active.
    15" mass-loaded passive
    Recommended crossover range: 60Hz to 250Hz
    Impedance: 4 Ohms (both woofers strapped together; otherwise two 8 Ohm inputs)
    Power Requirements: 20W to 350W rms (500W rms with Megawoofer)
    Dimensions: 23 x 32x 19" (HxWxD)
    Shipping Weight: 140 lbs.; 1" MDF construction
    Finishes: genuine oak veneer, light or dark, black cloth grill; satin black over oak or
    piano black over oak on special order
    Internal Wiring: 12 gauge Monster Cable
    Power Handling 350W, Impedance 4 Ohms (8 Ohms on special order)
    KIT w/cabinet $579ea
    KIT w/o cabinet $329ea
    Assembled $699ea
    Shipping in USA (48 states) FREE
    I have one of these puppys and it is awesome. I run it with a bridged Bryston (400 watts @ 4 ohms)in the front right corner of my listneing area and a HSU VTF-2 in the rear left and 180 degrees out of phase. (for Push-Pull)
    Hard to imagine much better than this, but the point is Why no VMPSers?
    John Casler
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    the specs are impressive, but you need to know how they are measured for them to be meaningful in the least.
    Brian and I got into it pretty heavy a while back...and there were specific inquires made on how those specs are generated...but (afaik)...no answers were ever offered from vmps.
    TV
  3. John A. Casler
    Apr 29, 1999
    475
    Hi Tom,
    Did you question the distortion, Decibel, Hz, or "all" the numbers for VMPS? Have you ever tested or listened "critcally" to the LARGER?
    If so, what was your impression?
    And have you ever tried the "push=pull" sub in front and rear "phased" properly, or do you have any advice or misgivings about it?
    John Casler
  4. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    Here's the thread Tom mentioned, which I started on AudioAsylum. Yeah, things got a little heated....
    http://www.audioasylum.com/audio/spe...ges/33338.html
    The VMPS subs do look like solid products, and the company in general has a good reputation. It would just be nice to see an apples to apples comparison with SVS, Adire, Hsu, etc.
  5. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    >>>Hi Tom,
    Did you question the distortion, Decibel, Hz, or "all" the numbers for VMPS?> Have you ever tested or listened "critcally" to the LARGER? If so, what was your impression?
  6. John A. Casler
    Apr 29, 1999
    475
    What I meant by Push-Pull was putting one sub in the front and another in the back of the listening area and phasing them so that as the front is pushing the rear is pulling and vice versa.
    Supposedly this causes greater air movement "if" it is set up well.
    I have mine set that way, and it seems to be superior to any other placement I have tried.
    Sorry for the confusion, I wasn't talking about a single "push-pull" sub like an M&K.
    I have been told that setting up this way causes each sub to accentuate or complement the others air movement/coupling.
    When I put both subs in the same spot I seem to get directionality.
    Thanks for the input.
    John Casler
  7. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    Oh ok,
    I usually recommend putting multiple woofs in the same corner of the room(preferably a corner near the key seats). This tends to maximize headroom. With dual vmps units though...headroom probably isn't a big concern.
    TV
  8. Stacy Huff
    Stacy Huff Second Unit
    Jul 13, 1999
    378
    After reading through that thread and the way that the VMPMS guy responded to TV, I wouldn't take a VMPS sub if the guy paid me to take it. My unsophisticated HT ears will be content with SVS.
  9. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    I agree Stacy!
    And not just Brian but there were some of his "sheeps",as well.
    Many of their statements,and "questions" were reflecting ignorance with arrogance,not the best combination if you ask me.
  10. Brian Fellmeth
    Jul 30, 2000
    789
    I was horrified by Brian's bellicosity at the time of that thread too, but I've come to understand where he is comming from. He is a passionate, opinionated guy- a New Yorker I think. He shoots first and asks questions later. He once picked a fight with nOrh and ended up sort of apologising which I think showed courage and class. Although I've never seen or heard his stuff, I'm sure its top notch and good value. I base this on the collective opions posted by his customers which are at or close to 100% strong positive.
