Why is the sensitivity of center channels greater?
Discussion in 'Archived Threads 2001-2004' started by Len Cheong, Nov 26, 2001.
  1. Len Cheong
    Len Cheong Second Unit
    Mar 18, 2000
    372
    Just wondering why center channels have a sensitivity spec greater than the L and R speakers. I don't know if this is true for all ht speaker packages but for many that I've read about this has been the case. Won't this result in a louder center channel vs the l and r speakers forcing you to lower the volome on it? Maybe there's a reason for it...
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Most of the centers I've seen have two woofers in an MTM arrangement, that can up the sensitivity. Of course, it's not a problem just to turn it down. The center is the best place to have high sensitivity, since it has puts the most demand on the driving amp.
  3. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Len,
    Sensitivity is a function of the number of speakers and
    the design and the efficiency of the speakers used.
    For exampe lets compare a set of Tower mains and a Center
    that use the exact same Mid/High section. The sensitivity
    of the Towers will generaly be a tad lower than the center
    due to the fact that the Towers also have a sub woofer built
    into the cabinent and the Cener does not have this.
    The more speakers, the more power it takes to drive them
    all at a particular refrence and thus the less sensitive
    it will be. Even cheap speakers in a cheap center section
    "could" be more efficient volume wise than a set of big
    buck towers just because it takes less power to drive the
    center. This doesn't make the center better.. Just a little
    more efficient. Of course there are always more variables
    than this, but that was a general rationalization of sensitivity.
