Why is Doctor Zhivago cropped so tightly?
Discussion in 'Archived Threads 2001-2004' started by ScottR, Dec 15, 2002.
  1. ScottR
    ScottR Cinematographer
    Apr 1, 2000
    2,646
    I compared the dvd of DZ to the vhs 30th anniversary copy and the dvd is missing SIGNIFICANT picture info on the left side. The dvd frame looks larger than the previous release as well. The right hand side of the frame is identical on both releases. I was shocked at how much is missing from the left...around 25%.
  2. Rain
    Rain Producer
    Mar 21, 2001
    5,015
    I wouldn't assume that the "more picture" on the left means that one is correct.
    I know that the old LD of Manhattan (also a Panavision film) showed more than it should have on the left, yielding something like a 2.55:1 AR when it should have been around 2.40:1.
    It's probably a safe bet that the DVD is more likely framed correctly than the old VHS.
  3. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,596
    257
    9,110
    Georgia (the state)
    Patrick McCart
    It's likely that the LD used a full apature source for the picture.
    The DVD is the correct version because that far side would have been masked by the soundtrack. You'll notice how off-center the LD image, which further shows the oddity.
