Dick
- May 22, 1999
- Rick
Beside the laser-disc-high price points I mentioned in a separate thread, I am truly agitated by the fact that Blu-Ray releases only occasionally take advantage of the relatively huge disc capacity.
True, TERMINATOR 2 (for example) on Blu-Ray is comparatively inexpensive, but does it include the extended cut? No. Other extras? No.
I'll be damned if I am going to do any "double-dipping" with the Blu-Ray format...I did that enough with standard DVD's, thank you. I will await what I consider to be a definitive edition and MAYBE buy it, if it's not going to set me back forty bucks. After all, this country is in an economic crisis state, and commodities like video systems and discs are just not going to do well if they are overpriced and lacking the incentive of decent added-value content.
Although some Blu-Ray releases actually contain features not available on standard counterparts (some of the more recent Pixar titles, for example), most instead DROP the added-value features from earlier releases.
WHAT THE F**k?
What about all that disc capacity?
You can present a long movie with loss-less bit rates and still have a ton of space for extras... isn't that part of the point of high-def discs?
If Hollywood really wants this format to take off the way standard DVD did ten years ago, they're gonna have to drop those prices AND offer nothing less (and hopefully much more) for added-value content than previous releases contained. Otherwise, Blu-Ray might very well become the same sort of niche product laser disc used to be.
WHAT THE F**k?
