Why does the camera add 10 lbs?
Discussion in 'After Hours Lounge (Off Topic)' started by Mike Wladyka, Feb 28, 2005.
  1. Mike Wladyka
    Mike Wladyka Supporting Actor
    Jul 24, 2003
    630
    Does anybody know if there is any science behind this?
  2. WillG
    WillG Producer
    Jan 30, 2003
    5,920
    317
    9,110
    I always thought that it was one of those myths. I figured it is because, perceptionwise, people tend to see themselves as thinner than they actually are when they look in a mirror.
  3. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    "So how many cameras are actually on you?"
    - Chandler Bing
  4. Aaron Reynolds
    Aaron Reynolds Screenwriter
    Feb 6, 2001
    1,715
    Ottawa, Ontario, Canada
    Aaron Reynolds
    Depends on the camera, or more specifically, it depends on the lens. Older wide-angle lenses are notorious for "barrel" style distortion that makes objects in the centre of the lens fatter. And actually, it's not just older lenses, but cheaper lenses, too.
    And hell, the Leica lens in my Lumix digital camera has hideous barrel distortion when it's zoomed all the way to wide, and that's a brand new, not cheap design. I have lenses for other cameras that are as wide or wider than that Leica lens and don't show any barrel distortion at all, but they all cost more than the whole Lumix camera.
    So, it depends on the lens, but that kind of distortion is almost entirely limited to wide angle lenses.
  5. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    I thought video added those pounds, as opposed to film?
    H
  6. Aaron Reynolds
    Feb 6, 2001
    1,715
    Aaron Reynolds
    I don't think that anything in the medium itself has that effect. Video may have (or had) cheaper lenses because it doesn't (didn't) require the same kind of resolving power that film does.
  7. Mike Wladyka
    Jul 24, 2003
    630
    cools, thanks
  8. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    The reason that the camera (film or video) appears to make people heavier than they look in real life, has to do with representing three dimension in only two.
    Things like barrel distortion (and other lens defects) and lens focal length are separate issues. The longer the lens, the flatter the image (of course)—but the apparent added poundage occurs in ‘normal’ 50-55mm (on a 35mm camera) length lenses.
  9. cafink
    cafink Producer
    Apr 19, 1999
    3,043
    37
    Carl Fink
    I don't remember where I heard this, but it was once suggested that this illusion occurs because a person has two eyes, set side-by-side, and can therefore see "around" an object slightly more than he can in an image recorded with only one camera. Because we see less of what's behind the person, we are tricked into thinking that the person is bigger.
  10. Mike Wladyka
    Jul 24, 2003
    630
    This was exactly my initial thinking, but I didn't know what the technical explanation behind it would be. I don't see how eliminating the depth would cause an object to look fatter.
  11. SarahG
    SarahG Second Unit
    Jun 6, 2003
    494
    I never actually thought that was true. Does it have to do with the allusion of the way pictures are viewed and the objects in the picture that are actually in perspective?
  12. Seth--L
    Seth--L Screenwriter
    Jun 22, 2003
    1,344
    With video, it's a depth perception issue. Video puts everything in focus, but the image is very flat.
  13. Steve Felix
    Steve Felix Supporting Actor
    Jan 17, 2001
    618
    Good lighting that models the subject well wouldn't have the added weight effect. Point and shoot flash photography, for instance, might have it because natural shadows are eliminated and the subject therefore looks more filled out.
    All bets are off if there is lens distortion, of course.
    Only in the hands of an amateur.
  14. Scott Simonian
    Scott Simonian Screenwriter
    Jun 20, 2001
    1,281
    I thought it might have to do with the aspect ratio. 4:3 isn't exactly a square. It is a litter wider than taller. That is how I saw it.
  15. ChuckSolo
    ChuckSolo Screenwriter
    Jun 26, 2003
    1,160
    I always thought this was an excuse that those among us use who suffer from an "overactive fork."[​IMG]
  16. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    maybe the camera is accurate, its just that people just believe they're 10 pounds lighter than they really are..
  17. Alf S
    Alf S Producer
    Apr 23, 2000
    3,115
    532
    4,110
    Alfer
    Not sure what you're talking about...I'm 190 and feelin' fine.....
    [​IMG]
    [​IMG]
  18. Lew Crippen
    May 19, 2002
    12,060
    It is not really video as opposed to film. The reason video has more in focus has to do with the size of the chip on which the image is focused and the focal length of the lens used to focus the image.. For example, 16mm has more depth of field than does 35mm.
    The professional HD video like Sony and Panasonic has about the same depth of field as 16mm. Not surprisingly, the chip size of these cameras is about the same size as 16mm film.
  19. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    Ack! Thanks Alf, now i have to wash my brain out with a salad.
