Why does Avia say calibrate to 85db on some tests, and 70 on the sub test?
Discussion in 'Archived Threads 2001-2004' started by JohnMW, Dec 10, 2001.
  1. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    I am just starting the calibration routine w/ the radio shack SPL meter, and I am not sure why Avia says calibrate speakers to 85db on some tests, and 70 on sub warble. What gives?
    ** Could it mean that during the sub warble you lower the overall volume on the receiver to around 70db to listen for dropoffs?
  2. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    I could have sworn it said to "at least" 70 dB on SPL to use the test. That portion of the instruction isn't meant to help get you to a specific level, but to make sure you have the volume up high enough to make the test easy to use.
