Why do receivers sound terrible in the store?
Discussion in 'Archived Threads 2001-2004' started by Brian_Tho, Jan 19, 2003.
  1. Brian_Tho
    Brian_Tho Stunt Coordinator
    Jan 8, 2003
    175
    I was testing the vr-6070 today at Best Buy, and it was hooked up to a JBL speaker system full size that is. Everything was setup correct on the receiver. I cranked StarWars up to 0deb on the dial and it did not sound very loud. The sound quality was not the greatest either it had a analog type sound to it. Thats the best way I can explain it. Is it the size of the area that makes it not sound that loud?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,185
    51
    9,110
    Katy, TX
    Wayne
  3. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    So thats why in most stores the sound system areas are in seperate small rooms.
  4. DonJ
    DonJ Second Unit
    Mar 5, 2002
    293
    Have you ever notice that almost all the Tweeters are pushed in and Best Buy, Circuit City, and sometimes at high end stores.
  5. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
  6. Jack Briggs
    Jun 3, 1999
    16,738
    129
    First, there's the issue of whether a receiver (or power amp or preamp) even has a "sound" in the first place (it's an issue that has been debated relentlessly since the late 1960s). Second, the speakers will determine more than anything what kind of "sound" you're hearing. And, third, the demonstration spaces in nearly all chain-electronics stores are terrible.
  7. Andy_SB
    Andy_SB Agent
    Jan 9, 2003
    46
    I agree with Jack - the "listening" areas at virtually all chain stores are horrendous. At my local Best Buy, all of their receivers are simply sitting on shelves with red buttons next to each of them which you press to select that receiver. They're all hooked up to some crappy-looking Sony speakers lined up in a row on the wall (presumably through some massive low-quality switching box).
    Not only is the area completely unenclosed, but Best Buy itself is extremely loud inside. Honestly, I wouldn't have been able to tell the difference between their cheapest KLH and their most expensive Yamaha receivers in that environment.
    Also, if a certain receiver sounds "quieter" than others, it could be because it's not hooked up/set up properly. When I was there, I noticed on some receivers that certain modes put out virtually no sound even just using the tuner. I went into some of the settings and in some cases people had set one or more of the channels as low as they would go.
    - Andy
