Why Can't I Play .avi Files?
Discussion in 'Computers' started by WillG, Jul 14, 2006.
  1. WillG
    WillG Producer
    Jan 30, 2003
    6,150
    428
    9,110
    I have some .avi video clips that I have downloaded over the internet. But whenever I try to play them via Windows Media Player, I get messages that WMP is requesting a codec and then that there is a error downloading the codec. Then, all I get is audio. I have tried other programs to run the files but I get the same result with just audio and no video. Can anyone tell me why this is and what I need to do so I can see the video?
  2. Jassen M. West
    Jassen M. West Supporting Actor
    Jun 22, 2000
    526
  3. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    Most AVI's use DivX codec. I see that is included in Jassen's link, so you'll probably be ok if you install them.
  4. WillG
    WillG Producer
    Jan 30, 2003
    6,150
    428
    9,110
    I'll give it a try, Thanks
  5. Bryan X
    Bryan X Producer
    Feb 10, 2003
    3,469
    3
    Yeah, I would bet just about anything you need to install the DivX codec.
  6. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    DivX codec
    XviD codec
    ac3filter
    ... plus some assorted others should take care of most avi's.
    http://www.headbands.com/gspot/ - Gspot will check the clip, then your system and tell you what you're missing.
  7. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,382
    28
    1,610
    "on a little street in Singapore"
    Yee Ming Lim
    Or download the free VLC player from videolan.org and use that instead of WMP.
  8. Kimmo Jaskari
    Feb 27, 2000
    1,528
    I've had some issues with that. For some files it's great, but when I tried viewing files over a network connection (a file share) my VLC started giving "twitchy" playback. The normal players (Bsplayer, WMP, etc) with external codecs however played flawlessly. It's just getting the codecs in place that can be a bit fiddly at first.
  9. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    +1 on that
    All you ever need is:
    1) FFDSHOW - decodes anything mpeg-4 related. No need to install Xvid and Divx.
    2) GSpot - once Gspot defines the codec go to free-codecs.com and download it
  10. MarkHastings
    Jan 27, 2003
    12,013
    VLC player is best suited for MPEG streams (not so much program files).
    We use it a lot to test out V.O.D. programs since WMP always has issues with those files.
