Why are WS TVs 1.66:1 when movies are >1.85:1
Discussion in 'Archived Threads 2001-2004' started by DaveF, Aug 13, 2001.
  1. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,986
    1,545
    One Loudoun, Ashburn, VA
    David Fischer
    It's my understanding that most movies currently have aspect ratios of 1.85:1 or 2.35:1. If so, then why was 1.66:1 (16x9) chosen for widescreen TVs?
    Was this to keep the distinction between 'TV size' and 'movie size' intact? Or are there more 1.66:1 movies than I realized?
    Thanks.
  2. Matt_Stevens
    Matt_Stevens Supporting Actor
    Dec 3, 2000
    747
    Read the FAQ. Widescreen sets are 1.78:1, not 1.66:1. And the difference between 1.78:1 and 1.85:1 on HDTV's cannot really be seen because of overscan.
    www.deceptions.net/superman
  3. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,986
    1,545
    David Fischer
    Thanks -- I knew I should check to see if 16/9 was 1.66 [​IMG]
    Where is the FAQ for WS TVs? The forum FAQ just has posting rules.
  4. Rob Michaw
    Rob Michaw Stunt Coordinator
    May 2, 2000
    132
    Matt -
    While I technically agree that overscan exists and 1.78 looks the same as 1.85 because of it, the losing of pictue still occurs.
    I don't even REALLY know the point of this message as I started reading it over again (becuase when I first read your message, I thought I disagreed with you). I think I am just trying to point out that the overscan just hides the fact that the sizes are different, as I know many who think that 1.85 movies as actually 16x9.
    [​IMG]
    rob michaw
  5. Matt Perkins
    Matt Perkins Stunt Coordinator
    Jan 20, 1999
    101
    I could be wrong about this, but I think I read somewhere that 16:9 was chosen as the HTDV AR (as opposed to 4:3 or 2.35:1) because a "widescreen" was desired, but too wide a CRT would make each picture tube unmanageably deep, heavy, and difficult to manufacture. So, 16:9 was chosen as a good compromise. (I've heard it called a "one size fits none" solution.)
    I think this is because the depth of a CRT is a direct function of the scan length (or "width") of the CRT's display. But I'm talking out of my ass here, since I can't imagine where I read that ...
    [​IMG]
  6. Andrew W
    Andrew W Supporting Actor
    Jun 19, 2001
    531
    I think some people get a little too picky about the aspect ratios in the 1.78:1 range. The differences REALLY are trivial.
    The following examples are based on my 57" TV.
    1.66:1 = 46.39 in x 27.94 in (7% difference in width)
    1.78:1 = 49.68 in x 27.94 in
    1.85:1 = 49.68 in x 26.85 in (4% difference in height)
    In practice, all three of these ratios fill my screen. My overscan is a bit less than 5%. Attempting to adjust the goemetry any further starts to cause the edges to collapse.
    Sometimes you just have to say "close enough" and watch the film.
    Andrew in Austin
    Sony DVP-S530D DVD Player
    Sony STR-DA333ES A/V Receiver
    Sony KP-57XBR10W Rear Projection TV (16:9)
    Infintiy SM 120 (L & R)
    Infinity SM Video (center)
    Infinity SM 165 (surround)
    Infinity BU-120 (subwoofer)
    [Edited last by Andrew W on August 14, 2001 at 11:02 AM]
