Who runs there back surrounds facing ceiling?
Discussion in 'Speakers' started by MikeyWeitz, Feb 4, 2005.
  1. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    My sectional is about 1.5' from rear wall. This weekend I will be connecting my JBL E10's and mounting them to the side walls.
    I have JBL N24's that I am going to use on stands for rear surrounds. Sicne their is not much room behind my seating position, I am thinking of having them firing up towards the ceiling.
    I know some here have reco'd that, so I would like to hear some more opinions of those that do it, how you mounted your speakers (or what they are sitting on, how high off the floor ( I was thinking of having them just below the top edge of my sectional-just out of sight when looking straight on).
    Opinions on your findings when firing them forward vs ceiling appreciated, especially if your seating config is similiar to mine.
    I also have the option of mounting my E10s, directly on rear wall about 4-6' apart and using the N24's on stands off to the sides, but have not made up my mind yet.
    Receiver is a pio 811 which does 6.1, but has connections for L/R center surrounds.
    Thanks.
  2. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    I'd do it.
    However, try it, and if it sounds funky, just scrap that channel.
    Turning that channel down would certainly help.
  3. MikeyWeitz
    Feb 10, 2002
    939
    DO which?
  4. Kenneth Harden
    May 13, 2002
    1,365
    Sorry - fire towards the ceiling or something not directly at you.
    If it works, fine, if not, forget it.
  5. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    I had my surround backs firing up to the ceiling in my old room. It actually made a pretty nice effect.
    Try it. You might like it.
  6. syeo
    syeo Agent
    Nov 3, 2001
    27
    I had the same dilemma as you with my sofa 1 ft away from the back wall. At first I had my back surrounds high on the back wall pointing downwards but still over my head. Then I tried putting them on the sofa table (behind the sofa) facing the ceiling. It made a 100% difference - facing the ceiling made the surround effect come alive much more. YMMV..
  7. MikeyWeitz
    Feb 10, 2002
    939
    Thanks for the feedback. I am gonna give it a try tomorrow.
