Who makes an amp with 7 channels at 200 watts or better per channel?
Discussion in 'Archived Threads 2001-2004' started by Henry W, Aug 7, 2001.
  1. Henry W
    Henry W Stunt Coordinator
    Jan 31, 2001
    128
    an amp with 7 channels at 200 watts or better per channel? I can't seem to find one anywhere.
    Best regards-Henry
  2. Derek B
    Derek B Stunt Coordinator
    Feb 11, 2001
    72
    I have never seen a Home audio amp that has seven channels. Usually they have five channels with two extra far rear channels. They usually only let you power 5 channels at once and the other 2 channels require an extra amp. This is frustrating for me too becuase I have a Pioneer receiver and I want to power the two extra back channels, but I have to buy antother amp just to do that. I do not understand why they can't just allow the unit to have more power to accomodate for the extra speaker outputs they incorporate!!
  3. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    B&K , i believe is going to release a 7 channel amp soon. I think it's called the 7270.
    - Chip
  4. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Me thinks that Outlaw is supposed to be coming out with one too. Around the same time as their pre/pro. I could be mistaken
    Dan Hine
  5. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,279
    12
    110
    Steven Simon
    Henry,
    In the future, can you please refrain from using teaser headers, and post some useful info in the header.....
    "Who Makes" will most likely get passed over by 99 Percent of our membership.....
    Steven R. Simon
    HTF Administrator
    Theater Pics Updated 7-26-2001
    Send Email: [email protected]
  6. Burke Strickland
    Burke Strickland Second Unit
    Jul 31, 1997
    271
    110
    Thanks, Steve, for pointing that out. I, for one, usually skip threads with "teaser" titles, and I know many others do too. But given that I already accidentally clicked on this one, and have some info that might be of interest ...
    ...check out the Integra Research RDA-7 seven channel THX-Ultra certified true Class A power amplifier (150 watts per channel @ 8 ohms and 300 watts at 4 ohms, which means it can handle the load as speaker impedence changes without "giving up the ghost"): http://www.integraresearch.com/articles.cfm?id=13
    In real terms, you are probably not going to hear a significant difference between 150 and 200 watts. And given its Balanced Audio Technolgy heritage (they designed it for Integra Research) this high-end baby is putting out "real" watts, not some inflated mid-fi number that runs out of gas when the music or soundtrack demands power.
    If I didn't already have so much invested in power amps already, I'd get one of these to mate with my Integra Research RDC-7 AV Controller (aka pre/pro). The RDA-7 isn't "cheap" in cost, build or performance. But it is really a great value if you truly need seven matched channels of high quality amplification.
    Burke
  7. Parker Clack
    Jun 30, 1997
    12,220
    76
    9,110
    Kansas City, MO
    Parker
    I edited the header of this post to address the question.
    Parker
  8. Carol Curtis
    Carol Curtis Stunt Coordinator
    Oct 12, 1999
    105
    JVC's new THX ULTRA receiver has 7 built in amps that are 120 watts per channel which should be out shortly. Now don't jump on me guys about JVC until it's out who knows if it's any good or not? From the pictures in the JVC audio catalog the insides look almost the same as a Sony "ES" receiver. As I've said in other posts, maybe JVC is going after the Sony "ES" line? No Dolby pro-logic II though. It also has seperate tone controls for all 7 channels.
    BASS: 63-1KHz 1/3 octive step
    MID: 250-4KHz 1/3 octive step
    TREBLE: 1K-16KHz 1/3 octive step
    STEP, Plus/Minus 6db, 1db step
  9. John Morris
    John Morris Guest
    If you can, I'd wait for the Outlaw 770. Supposedly 200 X 7 for less than $2K and made by ATI.
    Take Care,
    merc
    DFAST, 5C, DVI, HDCP, SafeAudio, Macrovision and Lewinski!!!
  10. Henry W
    Jan 31, 2001
    128
    Thanks for your responses-you've been very helpful.
    Best regards-Henry
  11. MatthewJ S
    MatthewJ S Supporting Actor
    Feb 27, 2001
    584
    I think that you'll start to find aproblem with normal 15amp outlets supplying enough current to 1 amp that needs so much juice, I could be wrong,but the installers that work for me keep telling the electricians wiring home theater rooms to install several dedicated (& isolated )20amp outlets near amp locations....
  12. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Burke,
    I see they upped the power supplies from announcement to current production.
    When announced, they had about 180w into 4 ohms, which indicated the transformers were too small.
    Nice touch that.
    Too bad the dang thing weighs 110lbs ;-)
    Not as bad as its big brother the BAT VK-6200, which weighs 200lbs fully loaded.
    At present only the B&K 7270 amp meets the criteria.
    John Kotches
    Contributing Writer
    Secrets of Home Theater and High Fidelity
  13. John Morris
    John Morris Guest
  14. chris c
    chris c Stunt Coordinator
    Jun 30, 1997
    206
    Well, Theta's Dreadnaught can have 7 channels, although I think at that configuration, at least two of the channels would be 100 watts/channel, with the rest 200 watts/channel
  15. John Kotches
    Mar 14, 2000
    2,635
    Chris,
    You are correct, Theta's Dreadnaught could hold 7 channels, but fails the criteria of 7x200w.
    John Kotches
    Contributing Writer
  16. Henry W
    Jan 31, 2001
    128
    Thanks again for all the helpful information. It is very much appreciated.
    Best regards-Henry
  17. Drew Eckhardt
    Drew Eckhardt Stunt Coordinator
    May 10, 2001
    246
    Extrapolating from what works for 2 channels, a decent 7-channel 200W amplifier should tip the scales at better than 120 pounds and draw over 40 amps at 120V when driving low impedance loads.
    The same in pure class-A (IOW, not playing tricks where the rail voltage tracks the signal) should be closer to 1/4 ton.
