TimothyE
- Dec 31, 2002
I just bought the Harman/Kardon AVR-325 from Costco. It is really DEEP. I have it all the way against the back of the cabinet, and the glass door JUST closes without hitting the volume knob. With just the TV left and right pre-outs put into the H/K, the default "Logic 7" sound coming out is so amazingly clear and open I can't believe it! It does SO much more with the sound to clean it up than my Yamaha (R-V902) did. I can't figure out if it's something unique to the H/K, or if a lot of the newer receivers will do that. So far, the 5.1 from DVDs sounds pretty close to the same as the Yamaha did, but it sounds slightly less punchy and boomy.
Because it's so big and might be a little overkill for what I need, I'm just going to try it out for a few days since Costco has such a good return policy. I've seen good reviews on the Pioneer VSX-D811S, which, according to what I THINK are our needs, does everything except HDTV component switching (28 MHz vs. the recommended 37 MHz). But after hearing the Logic 7 sound of the H/K, I'm wondering if any lower-end receivers can even come close.
I can't figure out how to "audition" a receiver without bringing it home and setting it up, dealing with my speakers and arrangements. I would like to try out the Pioneer VSX-D811S before I return the H/K, but I want to make sure I buy it from a store where I won't have a problem returning it.
How do you other members here go about this? Are there any stores you prefer to use for their "no questions, no hassle" return policy? West coast B&M preferred, but Crutchfield seems pretty good for online.
Tim
Tim
