Keith M.
- Apr 1, 1999
A while back I purchased a pair of the Klipsch KSP-S6 surrounds in white because I was using them in a living room home theater. Since then, I have bought a house and have almost completed my dedicated home theater room. The problem is I now need them black.
I was wondering If it would be safe to spray paint the cabinets black? They seem to be made of mdf...Do the front metal grills come off?
I also need to do this with my pair of Klipsch KSP-S3 also. And was going to replace the white speaker fabric with the partsexpress.com black speaker cloth...
Are there any issues I should be aware of? What type of spray paint should I use flat, satin, etc??
Looking to do this over the long weekend, so immediate input is welcomed.
Thanks in advance...
