Which TV would you get?
Discussion in 'Archived Threads 2001-2004' started by RaulT, Jun 8, 2001.
  1. RaulT
    RaulT Auditioning
    Apr 6, 1999
    12
    Hi everyone,
    I was scheduled to have the new 36XBR450 delivered till I stumbled on the Loewe Cal 2323 TV. It also does the 3/2 pulldown and from what the dealer told me it does better interlacing than the Sony. My dealer carries both TV's.
    Any advice which should I get? I'm not too familiar with the Loewe TV's.
    Thanks.
  2. KeithR
    KeithR Second Unit
    Mar 26, 2001
    258
    Loewe is a great looking/performing product, but is way pricy for the screen size. I would stick with the Sony...
    Of course, if you really want to go crazy, grab a NEC LT-150 and cheap screen and you will have a 96" diagonal! Yes, size is everything....
  3. Jeff Leeds
    Jeff Leeds Stunt Coordinator
    Aug 10, 1999
    131
    No question the Loewe is a better set, but how much into perfection are you? I'm not personally a big fan of the WEGA (they just look wierd to my eye) so for me I'd get the Loewe, but if you can look at the WEGA and like it then go for it.
    But when you compare them side by side, the Loewe should be noticably better....and more $$$ too.
    Jeff Leeds
    [email protected]
