David Giles
- Mar 6, 2001
My HT room is pretty small, basically rectangular at 15' long by 11' wide by 9' high (roughly 1450 sq. feet), and the only opening is a regular size door, which can be closed during viewing/listening. I have a Yamaha HTR-5280 receiver, older DCM Timewindows as mains, and new Def Tech BP2X surrounds and Def Tech C/L/R center channel. Right now I'm using a Sony SA-WM40 sub, so I'm sure any of the SVS's will be a major improvement. I use my system predominantly for HT, but listen to some music as well.
I ordered a powered SVS this afternoon, but am having second thoughts as to which of the "PC" models I should get. I'm assuming the guys at SVS will let me change my order tomorrow to another model before it ships, if I decide I really want to. Price isn't really an issue, at least not in the range of the SVS powered subs. I just want to make sure I get the best "fit" for my room/equipment/listening style.
Is anybody out there using an SVS in such a small room as mine? I'd appreciate any and all opinions as to what anybody thinks would be best in my room (obviously the sooner the better).
Thanks!
David
Thanks!
David
