bnlitin
- Feb 22, 2001
I've been using my SVS 2039CS for almost a year now and want to upgrade to either the CS+ or Ultra to get more output.
My current 2039CS sub clips on certain movies.
I only have space for one subwoofer (so I do not want to add another 2039CS).
Which would be a better choice - the 2039CS+ or the Ultra?
I also use the sub for listening to music, so it needs to be accurate and precise. I will be driving it with a Parasound HCA1500 amp (320W into 4 Ohms), crossed over at 80 Hz by the Tag AV32R preamp.
My room is 1200+ square feet with high ceilings.
Thanks for any advice.
Boris
Boris
