Which Sub???
Discussion in 'Archived Threads 2001-2004' started by ShanonS, Sep 25, 2001.
  1. ShanonS
    ShanonS Stunt Coordinator
    Dec 26, 2000
    239
    I'm having a hard time deciding which sub to get. I know this has been asked and asked again. I would really like an SVS 20-39PC, but it's just simply out of my range. I've had some suggest the Dharman, which looks really great, but then there's the current talk over at hometheatertalk about either bottoming or clipping. I'd really appreciate any comments from anyone here who has one, and whether you experienced this or not. Then there's the VTF-2 which sounds pretty good for the price and size. Can something that size really get down to 20 and keep it clean. Then, there's the last year's Vel's. CHT-12's and 15's can still be found for about the price of the VTF, or cheaper. So many choices.
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    If you can afford the Dharman, then that is the one to go for. The bottoming out/clipping is due to people testing out the sub, especially as it is new. The same thing happened to SVS a while ago. I really wouldn't worry about it. If you are, go ahead and get the VTF-2 or the Adire Audio Rava. Another possibility is getting a 20-39CS and something to power it with. Let the receiver handle the crossover.
  3. ShanonS
    Dec 26, 2000
    239
    At least one person responded.
    Thanks Bryan.
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
