steve paul
- Dec 13, 2001
I recently changed subs from an SVS to an velo HGS-18 - My room is only 10X24 - DO you think I am overdoing it? I wanted to get the best sub I could for under $2500 and the SVS's were to tall for my room. The HGS is a monster but how does the following compare to it?
HGS-15
HGS-12
Servo 15
Pair of Sunfire Signatures
Pair of Klipsch lf10's (can get two for $1200 new)
Martin Logan Decsent
Cost is no concern as I would go up to $3000. I just want the best sub for my room - and I am afraid I overdid it with the 18. Its AWESOME but could i get the same amount of bass from any of the above? Some would be cheaper, all would be smaller. I have two more weeks on my trial period with the 18. Which would you take from the above if you had a 10X24 room?
My system is
Denon 5800
Def Tech 2000TL's
Def Tech BP30's
Def Tech 2500 center
HGS-18
Just curious on others opinions.
HGS-15
HGS-12
Servo 15
My system is
Denon 5800
Def Tech 2000TL's
Def Tech BP30's
HGS-18
