Which SUB: Tempest or "XXX" (which is better?) (1 Viewer)
Chris Carswell
Ok, I started down the DIY sub road last week. I'm on a $200 budget so it will be tough, but I know you guys can help. I picked up a PE #300-800 150 watt plate amp cheap so now all I need is a sub. Box will be similar to Chris's Frustum Pyramid Tempest: http://www.angelfire.com/sports/RCcars/protosub.html/
I wanted to go tempest but will got over budget. I started shopping arround for others. I found this one "XXX" brand new that I can get pretty cheap & I have heard good things about it. I am not that good with stats so tell me what you guys think:
"XXX"
15" 4 ohm SVC
$85.00 my cost new (130.00 reg price)
PARAMETERS
Fs 31.88
QMS 4.72
QES 0.57
QTS 0.511
VAS (Liters) 123.79
REVC (Ohms) 1.8
SPL @ 1 watt / 1 meter (dB) 90.32
X-max Linear pk-pk (mm) 24 (so 12mm one way)
LEVC at 1k Hz (mH) 0.92
ENCLOSURE VOLUMES - Ported
Vented (Cu. Ft) 4
Vented to (Hz) 34
3dB down point (-3dB Hz) 33
Port Diameter (") 4
Port Length (") 12.25
Number of Ports 2
Tempest:
$150.00
PARAM VALUE
Re 3.50 ohms
Le 2.9 mH
Qms 6.7
Mms 195 grams
Qes 0.40
Cms 0.34 mm/N
Qts 0.38
Rms 3.5 N*s/m
Fs 18.8 Hz
Sd 779 cm^2
Vas 317 liters
BL 14.2
Xmax 16.4 mm one way
EBP 47
SPL 89.1 dB @ 1W/1m
No 0.51%
Pmax 400W per voice coil; 750W total to the driver
Distortion
Pete Mazz
First of all, the XXX driver looks to be set up for car audio use. I don't think your amp will be able to drive a 2 ohm load. That and a high Fs makes for a sub-standard HT driver. ;)
You won't be dissappointed with the extra outlay of cash for the Tempest. :D
Pete
Brian Bunge
Pete,
That's a single VC, not dual.
And I agree. Either get the Tempest or the Parts Express DVC 15" sub. I just finished a DVC 15" subwoofer today for a customer and I am thoroughly impressed! It's 175L tuned to 17.5Hz with the PE 250W plate amp and the 4" flared port. I was hitting 111dB on the "Coming Mother" scene from "The Haunting" from around 6' away and didn't have the sub anywhere near maxed out.
Brian
Chris Carswell
I just checked and it is a 4 ohm DVC woofer. I guess wouldn't be good to power just one of the coils to meet a 4 ohm load. I really should get something that goes lower than 30hz, dauh......
Jeff Rosz
heya,
do the dirty deed and go over budget and get the tempest. what else are budgets for? heh, im thinking the tempest will give the XXX a bloody nose in the car app too.
Chris Carswell
Jeff; Are you married? :) You know where that is going. WAF!!!
Jim; $100 hell yah. Wow those look gooooood but,when are they shipping:frowning:?
Thomas; I know.....What was I thinking. I did see an 18" for the same price as the tempest that went to 26hz but that is still a little high.
socker_dad
