Which sub is more musical?
Discussion in 'Archived Threads 2001-2004' started by Jason_Me, Jul 28, 2002.
  1. Jason_Me
    Jason_Me Stunt Coordinator
    Jul 17, 2002
    215
    I'm looking for a sub that will be used 100% for music. I've narrowed my search down to two subs:
    SVS 16-46PCi with Art 351 equalizer $779
    Velodyne SPL 1200 $795
    Which one should give the most musical performance, and seamless integration into a bookshelf system? Any thoughts would be appreciated.
  2. Ken Garrison
    Ken Garrison Supporting Actor
    Jun 1, 2002
    543
    My uncle has that 120 Watt Sony Subwoofer. That thing sounds great with music.
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Ken, both subs mentioned by Jason are a major step up from a 120W Sony in both output and sound quality. Not to belittle the Sony or anything, but if you think it sounds great for music you're in for a treat when you first hear a higher end sub.
    Jason, you won't be disappointed with either. Although the SVS will extend lower and go louder. Plus you are showing you can get an EQ for it as well that will help tame room problems (this can make a huge difference). I'll mention you may want to consider a Behringer Feedback Destroyer over the Art though (can be found for around $125).
    As for more musical, I'll provide you with two quotes from other threads. The first if from Jack Gilvey (he has a way of getting straight to the point), the second is from me, saying the same thing in a much more long winded way.
  4. Roger Kint
    Roger Kint Stunt Coordinator
    Jan 2, 2002
    161
    I believe the Velo is more musical because:
    1) Sealed enclosures are generally more accurate than ported enclosures. There are exceptions of course but this seems to be the general rule. At least in theory(in practice, there are actually some ported subs more accurate/musical than sealed ones, though).
    2) The velo has less distortion, less than 5% typ vs 10% for the SVS.
    3) Velo can't match the SVS in terms of SPL levels, but this is for 100% music, so you don't need the high SPL as much as for 100% HT.
    Also you may want to consider the HSU VTF-3 as I've read good reviews on that sub being more musical than the SVS. If you could get your hands on all three that would be the best way to decide, that way you'll know for sure what sounds the best to you.
  5. KeithBR
    KeithBR Agent
    May 13, 2002
    37
    Get a VTF-3 if music is what you are into.
    I have both brands of subs (SVS & VTF-3) and IMHO the VTF-3 sounds better (round and full) for music.
  6. Jason_Me
    Jul 17, 2002
    215
    Everyone on the avsforum is mentioning a bloating sound between 68 and 74Hz with the Hsu VTF-3. I plan on x-ing the sub over at 80Hz, so that would be a problem.
  7. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    Roger says:
    "I believe the Velo is more musical because:
    2) The velo has less distortion, less than 5% typ vs 10% for the SVS."
    Roger, where did you gather this information from?
    I take it that in #1 you have not listened to both these subs in direct A-B?
    Do you have the SPL's and other measuring conditions of #2?
    Just label me curious.
  8. Roger Kint
    Jan 2, 2002
    161
  9. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
  10. Roger Kint
    Jan 2, 2002
    161
  11. John F. Palacio
    Jan 6, 2002
    575
    Roger says: "I got the distortion figures from the respective mfgs and also on this forum. I don't remember or have the conditions, but you can ask the mfgs for that."
    I could find no distortion figures on the SVS site.
    The Velodyne site lists "less than .5% distortion" for the HG-15 II, but gives no SPL or frequency. (Meaningless)
    Dustin B quotes some of Tom Nousaine's measurements that I think put things into perspective, and bear no resemblance to the figures Roger posted.
    IMHO we should be careful of throwing numbers around here in an effort to steer audiophiles towards one product or another without knowing where these figures came from or the specifics of the measurements.
  12. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    On the distortion stuff, the older VELs (back to the F series) used to go weel above 10" when pressed. Not sure about the FSR series...but from what I've seen..the new HGS series caps THD
  13. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    Jason, if WAF didn't have a play in the decision, I would have bought the SVS over the SPL1200. That said, I bought the SPL1200 and *to me* music is absolutely incredible. That little beast blends in very well with my B&W 602S2 bookshelf speakers. I don't see a bad decision here either way. I'm sure you could find someone in the Bay area that would let you hear their SVS sub to compare to a dealer's SPL1200.
    I really had planned on buying the SVS "Tower O' Power" 20-39PCI when I first started on my quest. I'm sure I would be saying that it sounds great with my speakers had I bought it instead. [​IMG]
    Good luck on the purchase!
    Pete
  14. KeithBR
    KeithBR Agent
    May 13, 2002
    37
    No Jason,
    2 guys out of hundreds of post have mentioned the bloating in this range, and one of those guys, firepinch, has solved the problem. It has to do with their room modes and not the VTF-3. I had to use a P-EQ with my SVS sub to tame my room. Now I have no bloat at any hz with the SVS sub, even while playing at reference levels. I never had one with the Hsu.
    Both the SVS and Hsu products are incredible for their prices. No other subs can out perform either one of them under $1000. I have both and equally enjoy them, I just feel the VTF-3 has the edge for music over SVS.
    When it comes to HT I cant pick a winner. They are both equally awesome. I am amazed & upset at the same time, when I think of how much money I have spent on subs in the past that did not even give me this much performance.
    You just cant go wrong with either purchase. You can save a little money by going with SVS's new PC+ sub being released in August. One thing I will say about SVS, they have without a doubt, one of the best staffs in the business.
  15. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    As Keith and others have mentioned, room modes play a large part with in-room bass response. Get a parametric EQ (BFD, etc.) or other method of room tuning with whatever sub you decide to purchase...
  16. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    Tom,
    That new design you're toying with sounds awesome. When do we get to hear it?[​IMG]
  17. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    >>>Tom,
  18. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Tom,
    When talking about the distortion rise, it sounds (pun unintentional) a lot like an amplifier prior to clipping in terms of behaviour.
    Is this drastic rise in distortion relating to running out of excursion, or cone breakup? Colour me as curious about the physical factors involved in the clipping
  19. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Will you at least spill the driver size Tom? Maybe even whether it's vented or PR?
  20. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    >>>Tom,
    Contributing Editor,
    Widescreen Review
