John_VI
- Feb 18, 2002
Hello folks. Just found HTF recently and am enjoying learning about HT on an exponential curve!!
I'm shopping for new HT speakers, but am not sure I'll have the money to buy the entire package all at once. I have a Kenwood VR-309 receiver (100x5, DD5.1, DTS) which is okay. But....my current speakers came in a cheapo Sony "home theater in a box" set-up, including bookshelf mains, a small center and tiny surrounds. I'm also using a no-name sub. Overall, it's a pretty crappy speaker set-up, but it beats the heck out of TV speakers!
Regardless of which speaker brand I select, I plan to use mains/surrounds/center from the same mfr to get the best "matched" sound. The sub MAY also be from the same mfr, but not necessarily.
If I'm going to replace one set at a time - mains, center, surrounds, sub - which should I start with? Most of my use will be movies/TV, and I've read of the great importance of the center channel in movies. My thinking is that I should start with the center, then do the mains, then the surrounds, and finally the sub. The sub would definitely come last if I selected powered mains.
Thanks in advance for the advice!!
