Which speaker wire??
Discussion in 'Archived Threads 2001-2004' started by Mark Larson, Apr 3, 2002.
  1. Mark Larson
    Mark Larson Supporting Actor
    Mar 3, 2002
    537
    I went to the Shack and got my RS Gold interconnects. Yes i am cheap.
    But the 12 gauge speaker wire they list is at 99c per foot, with no mention of reels - so 100 feet would be $ 99 + tax. umm, no thanks!! [​IMG] [​IMG]
    I don't have a Home Depot in my neighbourhood, so any ideas where i can get some?
    Does wal-mart usually have that?
  2. Paul_Fisher
    Paul_Fisher Screenwriter
    Dec 27, 2001
    1,219
    You can try going to Sears.
  3. MichaelJ
    MichaelJ Agent
    Feb 1, 2001
    33
    I suggest you try bestpriceaudiovideo.com Look under the receiver section and you will notice speaker wire within the receiver discription I just purchased 12ga. oxigen free for .36 cents a foot thats $18.00 per 50 ft. roll Its very fine stranded copper wire
  4. Brian Treinen
    Brian Treinen Stunt Coordinator
    Aug 10, 1999
    135
  5. Mark Larson
    Mar 3, 2002
    537
    The problem here is the shipping - the 50' roll of AWG12 comes to 21.50+8.80 = $30.30. [​IMG] Not so good.
    Apart from Sears...?
  6. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    At radio shack don't they also sell automotive speaker wire that's 8 gauge extra insulated? It's like 99 cent's each wire so it would be 2 dollars for a pair of red/black wire.
    Anyone know if it would be ok to use 8 gauge speaker wire and I just twisted the red and black wire like a candy cane?
    partsexpress.com sells speaker wire as well.
  7. Russell _T
    Russell _T Supporting Actor
    Aug 26, 2001
    579
    Check your local high end dealer. Sometimes they can be suprisingly reasonable for speaker wire and accessories. I would also try www.partsexpress.com
  8. Dave Schofield
    Dave Schofield Second Unit
    Sep 30, 1999
    401
    The PartsExpress wire that was mentioned earlier is $40/100' roll shipped. I've bought two rolls from them now and really like the stuff.
