Which should I trust? My Denon test tones, or THX Optimode test tones?
Discussion in 'Archived Threads 2001-2004' started by James Zos, Jan 15, 2002.
  1. James Zos
    James Zos Supporting Actor
    Jan 7, 2002
    725
    The reason I'm asking, obviously enough, is because I get different readings depending on which I use. I don't mean one is louder than the other, though it is, I mean the levels appear skewed with my Denon, but balanced with the THX Optimode tones. Which to believe?
    I've started experimenting with a sixth rear speaker, and the Optimode doesn't put out a test tone for it, so I might have to use the Denon...but if the Denon's test tones are off...
    What do you think?
  2. EricK
    EricK Second Unit
    Jan 22, 1999
    287
    110
    Eric
    I would stick to the Denon's test tones. The THX tones can vary from disc to disc depending on what db level it was recorded at.
    Eric.
  3. Clinton McClure
    Clinton McClure Casual Enthusiast
    Jun 28, 1999
    4,502
    455
    4,110
    Central Arkansas
    Clint
    Or better still... Pick up a copy of AVIA or Video Essentials and use the test tones provided. I tend to believe they are more accurate than a receiver's internal tones since they are sent from the source unit (DVD player) and not generated by the receiver itself.
  4. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I would go with software tests. When you play a disk through your DVD player, through your cables, and into your receiver, and processed and decoded, the sinal could change very much. I was always told use a disc to calibrate. Using just the receiver tones could make for an incorrect calibration.
  5. James Zos
    Jan 7, 2002
    725
    Thanks for your responses!
