Which screen to get??
Discussion in 'Displays' started by tracy.t, Mar 1, 2006.
  1. tracy.t
    tracy.t Auditioning
    Dec 16, 2005
    7
    I just bought the panny ae900, thanks for all your advise, was hard to give up the 400 mir and 300 gc from blockbuster, anyways thats on its way however I also need advice on what screen to get tvauthority gave me a price of 1150 for the 106" diagnol screen from dalite high contrast cinema vision with pro trim, before I purchased this I wanted your opinions? is this a decent screen or should I go with something else? thanks again
  2. timNGY
    timNGY Stunt Coordinator
    Feb 16, 2006
    55
    Tracy,
    The Da-Lite High Contrast Cinema Vision (HCCV) is a very good screen. You can also go to Da-Lite's website to see the price (www.da-lite.com). I was also in the same position when looking for a screen for my Panasonic AE900. Also look at Carada screens as they have very good reviews and many supporters. Plus, its also priced lower than Da-Lite, but quality is just as good. I will be going with the Carada with the Brilliant White screen material. Hope that helps. Good luck.
