which sats to pick? (1 Viewer)
john seitz
I'm looking at the Def-Tech Pro Cinema kit 600 which I can get a good deal on now at Best Buy with the 12% coupon
or I can buy this kit from Focal:
Focal SIBSYSB Sib 525W 5.1-Channel Surround Sound System at $200 more then the Pro 600
my question is do you think the $200 is worth it?
And last option is a Boston Acoustic set
Boston Acoustics - Home Products
which is onsale for over half off at Circuit City -- the set up seems good and the price is even better! BUT is the price soo low because they are "one-step above HTiB?
Also is it bad for the Pro 600's if you hook up the fronts directly to the receiver and by-pass the double wiring to the sub?
My room is about a 16x18 or so.... in a finished basement with 8-9 foot ceilings -- powered by a Yamaha RX-V1800. I will use this 99% for TV and movies (80% HD) if that helps any?
thanks and i hope this was OK to post here
mat1
