Andrew Moore
- Feb 11, 2001
to cut circles? What bit do i need. I heard an upcut spiral bit will work but the only ones i see of those locally are dremel and rotozip bits not router bits. any suggestions?
if you're cutting plywood with a nice faceYou mean like this?
