Which receiver should I get?
Discussion in 'Archived Threads 2001-2004' started by JoelM, Mar 19, 2002.
  1. JoelM
    JoelM Stunt Coordinator
    Dec 16, 2001
    208
    Here is what I'm looking into
    6.1 Diva Swan setup 6.1/R3/C3
    Tosh65HX81
    Right now I have the older Onyko575(3 years old) should I keep this or upgrade it to a better receiver? I have no idea what receivers are capable of these days. I'll probably go to about $700 so any suggestions welcome.
  2. Wayne McRae
    Wayne McRae Stunt Coordinator
    Dec 28, 2000
    234
    If you like your Onkyo and don't mind waiting about a month,the new 600 should be in your range.Check out Onkyo's website for details.
    Wayner
  3. Chriss M
    Chriss M Second Unit
    Dec 14, 2001
    320
    with a 3yr old receiver you're probably missing most of the newest formats. Take a look at the harman kardon avr-520. You can get it for around $650 online. Has 7.1 capability, DTS-ES, Dolby PLII, and Logic 7. It also has amp inputs as well as pre-outs so that the amplifier section of the receiver can be used like a 5-channel seperate power amp, making it very flexible should you choose to add an external power amp later on.
  4. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
    You might also want to look at the Denon 2802. I am in the works of upgrading my receiver as well.
  5. RichardG
    RichardG Auditioning
    Mar 2, 2002
    14
    JM,
    With the current speakers you have right now, the Onkyo is plenty good enough. If you had more speakers that could utilize the 6.1 or 7.1 then I would recommend an upgrade.
