Which portable DVD player should I get?
Discussion in 'Archived Threads 2001-2004' started by Josh Wolfman, Mar 12, 2003.
  1. Josh Wolfman
    Josh Wolfman Stunt Coordinator
    Dec 19, 2002
    149
    I will be using it in my kids bedroom (13 inch TV), on trips (airplane and hotel), and also in the car for my kid. I would like to spend as little as possible but I am also looking for quality. Thx.
  2. Guy_K
    Guy_K Second Unit
    Aug 14, 2001
    470
    I recommend the Toshiba models, as they offer the best picture quality. If this is going to be used with a TV primarily, go with the SD-P1500 which can be found cheap online 400ish. If you will primarily be watching the screen, go with the SD-P2000, which has the best picture quality (albeit IMO the coloring wasn't as good).
