Which polk's to get?
Discussion in 'Speakers' started by Ryan.S., Dec 24, 2003.
  1. Ryan.S.
    Ryan.S. Extra
    Dec 7, 2003
    23
    Well a have an acquaintance that can get me stuff factory direct from polk audio for crazy prices... so I think I'm goin to get polk stuff. I can't decide what I want though. I have the onkyo 501. I can get this
    Polk theater system
    Or get the R20's real cheap... and buy them individually. or the LSi9's or the Lsi7's. But even with the crazy discount.. they're still expensive. But if they're THAT good. I might think about them. Let me know what you think. Thanks.
    Ryan
    edit** I can get polk, infinity, and harman kardon all for crazy prices. Right now I'm lookin at the infinity alpha 20's. So let me know.
  2. TylerZ
    TylerZ Stunt Coordinator
    Dec 3, 2001
    214
    First, if you can get them for 'crazy prices' get the most speaker you can afford, that way you won't want/need to upgrade so soon.
    Second, the LSi's are 4 ohm speakers which I don't think your 501 will do justice to.
    Third, I think you should take a look at the new RT series.
    Lastly, have you listened to them yet? Most CC's carry the R and RT line but not the LSi line. You might fine a higher end store in your area that carries them.
    Whatever else, get what sounds the best to you.
