Which Paradigm to get?
Discussion in 'Archived Threads 2001-2004' started by Al Jefferson, Mar 16, 2002.
  1. Al Jefferson
    Al Jefferson Auditioning
    Mar 11, 2002
    14
    Okay, I just ordered my subwoofer (HSU VTF-2). Now I have to decide on the other speakers. I went to my dealer today and I can get a pair of Titans, a pair of Atoms and the CC 170 for $540. Or, I can buy a 3 year old set of Monitor 7's, CC350, and Mini-Monitors for $800. What do you guys recommend. Should I go for the new speakers from the dealer or the used pair?
  2. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    I would get the Monitors. They are better speakers.
    I have the Mini Monitors and CC-370 up front and the Titans for the rears. I did some comparisons between the Minis and the Titans. The Minis have a better Midrange while the Titans sounded a bit harsh up high. The Performance series 3/4" CMC tweeter does not have as good of a range as the Monitor's 1" PTD.
    As far as them being used, Paradigm builds a very solid speaker that should work perfectly for many years. I don't think you have anything to worry about with 3-year old speakers. They come new with a 5-year warrenty. Will the rest of that warrenty be transfered to you?
  3. Alan Pummill
    Alan Pummill Screenwriter
    Jul 6, 1999
    1,262
    I second Brian's opinion!![​IMG]
  4. EricHaas
    EricHaas Supporting Actor
    Dec 25, 2001
    667
    I third.
  5. Matt_Sulli
    Matt_Sulli Agent
    Mar 13, 2002
    38
    i also agree, monitors are simply a better speaker
  6. Mark Hobbs
    Mark Hobbs Stunt Coordinator
    Mar 3, 2002
    142
    I have the Titans due to budget constraints, but I did an A/B comparison with the Titans and the minis and the Titans and the Monitor 7s. The main thing I noticed is you get a wider and fuller mid-range sound from the monitors than the Titans.
    I disagree about the Titans sounding harsh "up high". The Titans sound great and are an incredible value for $200. But if you can afford the monitors, they will definitely sound better.
    I don't think speakers being used is a big concern, if you trust the person you are buying them from.
