Which Paradigm ADPs? (1 Viewer)
AaronG
Hi guys,
I'm getting the Paradigm Studio 60's, CC, and a PW 2200, and I'd like to get some ADP's. I think the Studio ADP's are too large for where they need to be placed, so I'd like to know which ADP's would be a good match to the above set-up.
Aaron
Robert Ma
Hi Aaron,
I had the same problem. Although I wasn't looking at the studio adps, I wanted the adp-370s and they were too large. I went with the ADP-170's and it worked out great for me. So maybe if the 370's fit your size, maybe they will work.
I think matching the front 3 speakers is more important than the rears. Maybe someone else wouldn't reccommend this but as I said above, it worked for me.
AaronG
Thanks Robert!
Does anyone else have an opinion? I'm leaning toward the ADP-370, but it isn't much smaller than the studio. Will the 170's do the job? Also, if I go totally nuts, is the studio worth the extra cash (around $400 more than the 370s)?
thanks,
Aaron
ChewyWaffles
