Tom: Where do you have your sets of speakers placed?
I'm looking at putting my dipoles to the side and slightly behind my sitting position, and then when I get a new set of Mains, (probably the Reference Studio 40's from Paradigm) I'll put my Titans in the back corners of the room.
I have a Denon 3300 that allows me to do what you can do as far as A, B and A&B configurations.
Greg, I to have a 3300, my couch sits about 4 feet into my room, so I have the dipoles on either side of the couch, and the mini monitors are placed behind me in the corners of the room. It is nice to be able to pick and choose between th two or have both running at the same time. I wouldn't mind addind a 3802 or a 4802 and rear centers though.
Your setup sounds like what I will be moving to in the future.
And the 3802 will be nice (or whatever replaces it) in a couple of years. My 3300 is only about 14 months old and sounds quite nice. I'd look at the 4802, but I don't need its high-priced remote. I'd rather use one of my Home Theater Master remotes or my Pronto.
Actually, I wouldn't mind just upgrading the whole speaker system to Studio 40's, CC-370, ADP-370's and Mini Monitors (1 in each corner and one in the center rear).
Dreaming...........!!!
Johnson: I couldn't access the first article, but second article spends the bulk of its time referring to using Bipole and Diple Main speakers...... not so much as surrounds, which is what I think we are talking about here.
