Christian_M
- Feb 28, 2001
Hi all,
I am interested in making DIY cables. My first exposure to this idea was Chris White's site. He recommends Canare tools, connectors, and cable, and warns that other cable may not work with this setup. Some posts on this forum seem to contradict this. I also checked out the Max Rochlin Memorial Cable, which uses Canare connectors on Belden 1505A.
My question is this: If I want to...
* use the Canare stripping/crimping tools
* use Canare crimp-on connectors
* not do any soldering
* make audio interconnects
* make subwoofer cables
* make digital audio cables
* make composite video cables
* make component video cables
* make cable/sat/ant cables (F-type connector)
* and only buy one type of cable...
...what kind of cable should i get? I am looking for the highest-quality cable for the above tools/process. It is feasible to use the same type for all these applications? Any comments about crimping dies, connector model numbers, etc. would be appreciated.
-Christian
-Christian
