Which of the listed subs will BLEND the best with M
Discussion in 'Archived Threads 2001-2004' started by David Barteaux, Jan 10, 2003.
  1. David Barteaux
    David Barteaux Stunt Coordinator
    Jan 6, 2001
    179
    Which will sub below will blend best with my M&K speakers that have a frequency respone of 80Hz-20Khz. I am using Denon reciever with speakers set to small (80Hz sub out crossover). I am concerned that the M&K sub will crossover better than the others. Could that be true?
    SVS 20-39 PC+
    Paragigm Servo-15
    M&K MX-150 THX
  2. Jason Reich
    Jason Reich Stunt Coordinator
    Feb 19, 2001
    90
    All three are great subs. As an owner of one I would recomend the SVS - with such a flat response they tend to blend seemlessly with all the speakers I have heard it with.
  3. David Barteaux
    Jan 6, 2001
    179
    Don't the M&K subs roll-off at 80 hz better to match THX speakers?
  4. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    David, any subwoofer can be set to roll-off at any frequency you'd like, either using the internal crossover in your receiver or the crossovers built into most active subs' amplifiers. The options listed are all great subs and the Servo 15 might be a good idea since you'd have to pay more (compared to US customers) for the SVS. I would think the SVS would have a bit of clean output advantage over the others at the lowest frequencies given its vented design.
