Which Mirages for surround (an rear)???
Discussion in 'Archived Threads 2001-2004' started by George Kouzev, Jan 31, 2003.
  1. George Kouzev
    George Kouzev Stunt Coordinator
    Jun 30, 1997
    78
    I have a pair of Mirage M5 speakers on the front and a Mirage MCsi in the center. I am about to change my side surround (PSB Alphas) with one of the following:
    - Mirage OM-R2, an omnipolar surround.
    - Mirage Omni sats, a very cool looking and relatively small piece with the widest possible radiation pattern
    My HT room dimensions are 12x29x9' as the fronts are positioned across the 12' side. I currently use multichannel for movies only but SACD/DVD-A player is coming soon too.
    I would place the PSBs as rears (in my future 7.1 setup) but may go Mirage all the way.
    Any advise will be appreciated.
    GK
  2. Anthony Lengyel
    Jan 28, 2003
    25
    I just bought the Omni FX for the rears. They best matched my Monitor 7's from Paradigm and I like the fact that they disperse the sound in a 360 degree manner.
    They sounded the best from all the rear speakers I listened to. They remind me of the Paradigm rears but alittle cheaper. They look very cool too [​IMG]
  3. MikeH1
    MikeH1 Screenwriter
    Oct 25, 2000
    1,492
    I have the Om-R2 for about 2 years now and I like them a lot. But I do have some issues, mainly placement.
    The design of these speakers requires perfect placement. The way the tweeters are angled it can make a big difference. To use these effectively (and going by dolby labs recomendation for rears) you want a rear wall behind your seating area for these particular speakers so the one angled tweeter can bounce off it. Truly, these speakers are great rears but room design plays a key role in getting the most out of them. I have had these speakers in a few different set ups as I have moved into new places and they always sound way different each time. The last place I had a rear wall for like half the room width, so basicly the left speaker had something to bounce off of while the right didn't. I always could tell...the left was more spacious and more pronounced. The worst part was, other than changing the volume/delay levels within the amp for the rears (but of course this didnt cure the radiation pattern of these speakers) there was nothing i could do, I had them set up quite ideally.
    If you go with these I recommend highly you move them around finding the perfect spot before doing anything permanent.
    Also, keep in mind their cut off at 80 cycles.
