Which is better for CRT Front Projection, 16:9 or 4:3?
Discussion in 'Displays' started by gene_d, Feb 17, 2004.
  1. gene_d
    gene_d Auditioning
    Feb 16, 2004
    7
    Could use some good feedback before I build my screen. I want a 120" diag screen but not sure which format to use, 16:9 or 4:3. I will probably be watching dvd movies and sat tv equally. I have a Sony VPH-1270Q CRT projector.
    Any ideas???
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Then you need to determine what is more critical of the two types of programming. Do you sacrifice the quality of the best stuff for the sake of the bad ...? Like keeping all the students back one year because the underachievers might feel bad otherwise.
    Regards
