JackIR
- Nov 27, 2001
I was thinking of getting an EQ for my sub. It is between the Rane PE17 or the Symetrix 551E? They are both about the same price, so which do I buy?
I am using three channels only and find that it reduces overall low frequency SPL by about 4db which I assume is the source of the heat.
Robert, it has nothing to do with heat. I assume you used the EQ to tame (i.e., reduce) response peaks? The net effect of this is reduced gain. You can compensate for this with the EQ’s gain controls, or the volume control on the sub.
Happy Holidays,
Wayne A. Pflughaupt
