Mike Rivera
- Dec 11, 2002
Hi:
I just bought a Gateway 42" HD Plasma. I know there's a lot better out there, but not for $3,799 (including a free 13" LCD television), which is what I paid.
I want to take advantage of the DVI connection, but I'm confused. There's Dual Link and Single Link and there's DVI-I and DVI-D.
I'm using Comcast Digital HD Cable (in the Sacramento area) and an thinking of getting the V, Inc. Bravo DVD player which supports DVI and I'm told works very well with the Gateway (and Sampo) Plasmas. Is this true?
Should I use the DVI input on the monitor for HD cable broadcasts or DVD? I'm guessing DVD since I care more about quality on movies than broadcast shows. Will I notice a difference from the component cables on using on my DVD player now?
Which cable do I need (single/dual, I or D)?
Mike
Mike
