Which DVI cable do I need?
Discussion in 'Displays' started by stratos, Apr 6, 2004.
  1. stratos
    stratos Auditioning
    Feb 3, 2004
    4
    First of all, great Forum- [​IMG] [​IMG]
    I have a SONY 46 DVI-HDTV
    Denon 1804
    Panasonic F85
    Motorola DCT 6200 HDTC Cable Box
    Boston Acoustics 75s and CRC Center
    Bose Bookshelf rears
    Sony 12 inch sub
    I would like to use a DVI cable to connect my HDTV box to the TV, but there seems to be a few types of DVI cables out there. Any idea on which one I need? Do you think it will make any difference?
    KC
  2. Ralph B
    Ralph B Supporting Actor
    Apr 27, 2003
    584
    get a DVI-I cable as it will do both digital and analog for you. I believe anyway. [​IMG]
  3. David WS
    David WS Stunt Coordinator
    Apr 25, 2002
    98
    Actually you'd be safer with a DVI-D cable. The "I" version will have extra Analog pins added. If either your TV or STB is "Digital Only" the DVI-I cable will not plug in. There are also DVI-A cables but they are very rare as they are Analog only (what's the point? just use a vga cable.)
    This Site has a good description of the differences in the "About DVI Cables" section.
    Dave
  4. Ralph B
    Apr 27, 2003
    584
    good to know , didnt know that.
  5. stratos
    stratos Auditioning
    Feb 3, 2004
    4
    All great info!
    thanks!
