Which DVD player should I get? (1 Viewer)
Robert CH
Here's a typical newbe question. Last week my 12 year old 27" TV mercifully died. I have replaced it with a Panasonic 36" HDTV (model CT 36hx42) and also bought an Onkyo model 600 reciever. I'm ashamed to tell you what kind of speakers I have (the name rymes with "rose"), but I'll be replacing them soon.
I want to get a new DVD player with component video and progressive scan. I don't want to overbuy or underbuy. Any suggestions on what would go good with my other stuff?
Chris Clarno
Oceano, CA
Christian
Depends what you're looking for. A good entry level player from Panasonic is the DVD-RP62S. Sells for about $150 Progressive-scan, Plays DVD-Video, DVD-R, CD-DA and CD-R/RW, plus MP3 and WMA files recorded on CD, Super high-speed scan (5 speeds, up to 200x, selectable via shuttle dial), "Dialogue Enhancer" boosts dialogue so you don't miss a word, even during loud sound effects (I like this feature!)Dynamic range compression keeps sound levels even, 480p/480i-switchable component video outputs, plus S-video and composite A/V outputs; optical digital audio output, an odd addition is a dedicated subwoofer connection...
AlohaTiger
