which dvd player is better?
Discussion in 'Playback Devices' started by Tony Du, Dec 2, 2005.
  1. Tony Du
    Tony Du Auditioning
    Nov 15, 2005
    10
    im looking at the Panasonic DVD-S97S and the OPPO OPDV971H wondering which one is better as they both have very good reviews? thanks
  2. Chris Gerhard
    Chris Gerhard Screenwriter
    Nov 8, 2002
    1,285
    4
    110
    Chris Gerhard
    Both are very good, although the Panasonic DVD-S97S is in my opinion a little better overall, it is not worth the extra $100 it is likely to cost. Check for needed disc format compatibility to make sure you are covered before purchasing either.
    Chris
  3. Tony Du
    Tony Du Auditioning
    Nov 15, 2005
    10
    you mean like whether or not it can play cdr's or dvdr's?
  4. Chris Gerhard
    Nov 8, 2002
    1,285
    4
    110
    Chris Gerhard
    Yes and whatever else you need.
    Chris
