Which Dvd Player? Help!!
Discussion in 'Archived Threads 2001-2004' started by Nicholas*C, Dec 27, 2002.
  1. Nicholas*C
    Nicholas*C Auditioning
    Dec 19, 2002
    2
    Ok, guru's I'm looking for a good dvd player for around $200. Any suggesstions or brands that I should stick with? I was told i need one with a digital coaxial cable because the sound would be better than optical. I kind of want one that is black in color but will buy what I can.
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Nicholas: There's no audible difference between optical or coaxial digital inputs. Either one is fine. JB
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    My recommendation would be to steer away from Pioneer DVD players, as there are many of their players are known to have compatibility issues with certain discs.
    Personally, I'd stick with Sony or Panasonic for DVD players at that price point.
    Yes you want a player wiht digital output, vs analog only, which some of the cheap players are coming with to hit that under $100 mark. No digital output means no Dolby Digital/DTS. As Jack said, there is essentially no difference between optical and coax.
  4. TimTurtino
    TimTurtino Stunt Coordinator
    Dec 17, 2002
    156
    Secrets of Secrets of Home Theater and High Fidelity Audio pretty much unequivocally recommend the Panny DVD-RP82 in this price range. The CP-72 has, supposedly, the same guts, except for being a 5-disc changer and having a fiber-optic out instead of a coaxial...
    Me
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    You do know the XBox is $199 and add in the $29 DVD remote and you have both a DVD player, game system and music server in one? Something to consider.
