Which Driver is more musical Tempest ,Shiva ,DPL12, Or titanic
Discussion in 'Home Theater Projects' started by Andre Baptiste, Jan 4, 2004.
  1. Andre Baptiste
    Dec 21, 2003
    42
    Hi Folks i am gonna build a sealed sub so i want to know which driver is gonna give me more of a tighter flat response byeeeeee
  2. Justin Ward
    Justin Ward Supporting Actor
    Jun 6, 2002
    673
    I've heard the DPL12 can be very musical.
  3. Jake K
    Jake K Stunt Coordinator
    May 22, 2003
    132
    I would use two DPL12 drivers in a 5 cubic foot enclosure with one of the drivers flipped over and wired out of phase with the other one, which would make them move in the same direction. That is supposed to eliminate some distortion. I think that's a push-pull configuration.
  4. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Yes. It depends on the box design and room placement more the the driver itself. That said if you're looking for musical try the DPL12 in a 75 liter sealed box.
  5. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    Your room is going to have a bigger effect on what sounds "tight" more than any one of those drivers. If you haven't already, invest in a Radio Shack SPL meter/test cd(you can download and burn your own free test tones if you have a cd burner) and look into an eq for what every sub you choose. The Behringer Feedback Destroyer(BFD) is very popular eq and it runs ~$120. This will have a bigger impact on sound quality than the difference between any of those drivers
  6. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    The DPL12 is probably your best bet for music but I have to agree with Frank. All is for naught if your room modes kill it. I can't imagine being without some bass management.
