Which crossover freq on Denon 2802?
Discussion in 'Archived Threads 2001-2004' started by Vlad D, Feb 3, 2002.
  1. Vlad D
    Vlad D Screenwriter
    Oct 24, 2001
    1,076
    Vladimir Derenoncourt
    I'm using a Denon 2802, and I have Boston Acoustics VR-M60's as my mains and a Velodyne SPL1200 sub. I currently have my speakers set to small and the crossover at 80Hz. My other choices are 100Hz or 120Hz. Am I using the correct setting. It seems that I have to turn the volume up on the sub to at least the half-way mark to really hear the bass. Any suggestions?
    Vlad
  2. Vlad D
    Vlad D Screenwriter
    Oct 24, 2001
    1,076
    I have my sub set to bypass its own internal crossover so that the crossover is done by the receiver.
  3. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    The Boston Acoustics VR-M60 has a 6.5" woofer and should work well with an 80 Hz crossover.
  4. Royce H
    Royce H Stunt Coordinator
    Mar 10, 2001
    61
    Vlad, you might also want to check to see what your receiver's sub volume control (I think Denon calls it the subwoofer channel level--see page 17 of the manual) is set to. Default is 0, I believe...[​IMG]
