JimmyK
- Jun 21, 2002
- Jim
I am expecting my Anthem AVM20 v2.09 to arrive this week and am getting together things I need for installation.
I read in the owners manual that to upgrade the software, you need to use a serial cable DB9 (male plug on one end and female plug on the other) straight wired. In my situation, I would need a 40ft. cable.
Now, I'm not much of a computer person, so when I did a search for such a cable, I wasn't exactly sure for what I was looking.
I did find a cable on this site:
http://www.techdepot.com/product.asp...info=Tech#tabs
It's described as a "50ft. Serial Extension" with a DB9 male plug on one end and a DB9 female plug on the other end.
Is this the cable I need? Does it matter that it doesn't say "Straight Wired"?
If this is the correct cable, is the site mentioned above a reliable internet company? Any other place you recommend I look? Should I be able to find such a cable and length locally?
Thanks for any help/suggestions you can provide on this subject!
JimmyK
JimmyK
