Which Component Cable: Best Buy or Radio Shack? (1 Viewer)
Rob White
Today I'm going to buy an in-store component cable. I don't want to wait for something to come in the mail, so it's pretty much Best Buy or Radio Shack. Best Buy had a 12 ft for around $35 and I haven't checked Radio Shack yet (although I read a lot here that their salesmen are somewhat clueless on the component cable issue. Can I do better than Best Buy's?
Thanks in advance for your help,
Rob
Receiver: Onkyo 595
Speakers: Energy Encores
TV: Sony 43T75 rptv
DVD/CD: Panasonic RV-31
James Q Jenkins
I've read uncomplimentary things about Radio Shack's video cables, though I use many of their audio cables myself. I'd go with Best Buy if given those choices.
-JQJ
I have the Radio Shack cables for both my HDTV STB and Progressive scan DVD player. I think they are great and have nothing bad to say about the quality.
However, what I have is the Gold AV cables instead of the Component Video Cables. These are the same cables as the component cables except they have Red, White & Yellow rings on them isstead of Red, Green & Blue. They are also about $20 cheaper.
Don't spend extra money on the Component version, just buy the Gold AV cables and make sure that you stay consistent with which jack you plug the cables into.
Anthony S
In a town the size of Richmond there must be other A/V shops or appliance stores that you could check out. They would most likely have a couple of brands at different price points or at least one brand with two or three different levels of quality. I bought some Tributaries here in Ann Arbor from a local home appliance shop and have been very happy with them.
David Judah
I haven't had good luck with Radio Shack cables in the far distant past, but others have so, YMMV.
I would make sure they are all video cables though if you don't go with a specially labeled component set. I wouldn't recommend using an AV cable that has one video and two audio cables.
DJ
Bob McElfresh
I thought someone a few months back determined that the MegaCable sets of L/R/Video from Radio Shack were all made with identical 75 ohm coax and connectors.
This makes sense from a manufacturing point of view. Just slap different color bands on the RCA plugs and you have component video and L/R/Video bundles coming from the same line.
And as far as I know, 75 ohm coax works fine for audio unless you have a more exotic system that wants the 50/110/300 ohm coax.
TheThrillisgone
