Which banana plugs? (Help me pick b/t these two)
Discussion in 'Home Theater Projects' started by MichaelDDD, Oct 25, 2003.
  1. MichaelDDD
    MichaelDDD Supporting Actor
    Sep 29, 2003
    616
    Mike
    Hi all,
    I've decided to purchase banana plugs for my HT redo. Hooray for me.
    The front/center speakers will use the plugs. Surrounds won't (bananas won't fit b/t speaker and wall) All connections to the amp will use bananas.
    Going with PartsExpress for the plugs and 12 gauge cable (the SoundKing stuff)
    Which banana plugs are better and why, please?
    There's an insignificant $.70 diff b/t the first and second one. The first one uses "dual setscrews" to secure the cable. The second one uses a compression fitting which is allegedly better than setscrews. [​IMG] Thanks!
    1165 at $3.90/pair
    [​IMG]
    330 at $3.25/pair
    [​IMG]
  2. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    I've been using these Dayton Bananas since 2001 and they seem to work very well. They come 4 per pack [​IMG]
  3. MichaelDDD
    Sep 29, 2003
    616
    Mike
    Hi John,
    Hey, those are nice too. Hmm...$6.25/pack works out cheaper than the cheapest option I had. [​IMG]
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Get the WBTs [​IMG]
    Between those two, I'd get the 1165 because I DO NOT like the screw-compression type. The Daytons will be just as good as the 330s at a much lower price.
  5. MichaelDDD
    Sep 29, 2003
    616
    Mike
    Hi John. [​IMG]
    Please explain to me what is wrong (or unpreferable to you) about compression-type bananas.
    I've never used these things before and would like to maximize my HT dollar. [​IMG] Sounds like something from Consumer Reports.....
