Daryl L
- Sep 26, 1999
Hi, I bought the toshiba TN50X81 hd-ready 4:3 set 3-15-2000, calibrated with Avia first, ISF'd by Louis Carliner in June 2000.
Now I just bought the 57HX81 and with my RCA DVD player set to 16:9 Widescreen in the menu and the TV set to Full Avia doesn't appear to display some of the menu's or patterns properly for widescreen adjustments. I have to set the dvd player to 4:3 Standard and TV to Full to check my overscan(which suprisingly is set to 4% on top, left and bottom, and 5% on the right side right out of the box) and the convergence patterns(which also suprisingly straight as heck right out of the box, even better than the geometry and convergence was on my TN50X81 before and after being ISF'd).
I went ahead and ordered Video Essentials yesterday(I know it's being replaced but current dvd has a couple uses the new one wont that I read about, cant remember them at the moment) I'll order the new Digital Video Essentials later.
My question is:
Which patterns should be avoided on AVIA?
Which patterns should be avoided on VE(example: VE's overscan from what I understand isn't centered properly).
I think we all could benefit from this list of Use and Don't Use patterns of Avia and VE.
Thanks for any info.
My question is:
